1 - 9 of 9 Posts
I removed my drip rails in the bodywork resto process. I really would not want to put them back on unless I absolutely have to...but I noticed that since they have not been on I have been getting more water flowing into my truck. Mostly on the rockers...and some in the back coming in around the driver side of the tail gate a few inches in front of the tail light near the spare tire well. I also have old weather stripping in place now, so I was wondering if putting in new stripping after I paint the truck will prevent water from getting in or will I ultimately have to put the factory drip rails back in place? What say the GMTC Gurus???:glasses:
good question, I have seen guys put new weather stripping in and it be fine. Try that first
Super Moderator
I'd leave them on. They were put on for a reason. Without them, rain that runs off the cab of the truck can sit directly on the weatherstripping where it will eventually get past and leak into the cab.
Discussion Starter #4
I think if I put them back on I might opt for double sided tape instead of re drilling the holes...then I can put a bead of silicone... this way they will still not be "permanent" It makes me kind of pissed that I spent all that time filling the holes and sanding....
Discussion Starter #5
Would not those rain guards (usually smoked plastic or chrome) serve the same purpose? If so, I might put those on instead.
Super Moderator
Those keep rain from getting in through the window when they're slightly open. The drip rails are for the actual door jamb. Take a look at the door jamb from above the side of the truck and you'll see the gasket pretty easily.
Grit, you might get away with it in Florida, but mine doesn't have drip rails & the rain puddles on top of the weather strips & when you open the door it dumps on the threshold, the rockers, the carpet, & the edge of the seat. It also dumps on me if I'm in a hurry getting out & don't give it time to run off :grrrrrr:
Discussion Starter #8
Yes, I have also noticed when I open the door the water runs down the sides onto the rockers...and then when I shut the door I get a "shamoo" splash:happy:
I will most likely put them back on. I will drive around with the new weather stripping in place and see how it does in the rain.
Good news is I put in another five hours of body work. Another few hours (maybe 4) and I think she is ready for paint:great:
Time to order the paint!!!!! I think I am going with Hot Rod Flatz flat black. Here is a link to some of their paint:
http://www.tcpglobal.com/kustomshop/ksflatz.aspx
1 - 9 of 9 Posts
