1 - 20 of 22 Posts
Yes you can lift the front of your truck with new keys. Those ones look like they would do the trick.
Welcome to the club,eporter2980.
Depending how much you want to lift the front end, you might be able to get away with just cranking the torsions up a bit. I would try that and see how you like it before I bought the keys. On your truck you can go up approx 1.5 in without severely changing your ride quality. Make sure that you keep track of how many complete 360 deg turns you make with your wrench, and do the same on the other side. 5 or 6 complete turns seems to be the trick. Also make sure that you get an alignment soon after your adjustment. If you don't achieve the stance you were looking for, you can always let it back down the same number of turns that you cranked it up, and you'll be back at the stock setting.
Nice before and after pics Adam, im gonna try cranking my stock ones up
KyleZ71, measure your truck before you start so if its to stiff after you adjust the bars go can go back down to the stock setting. Just a suggestion.
I looked at the keys that eporter2980 put a link to. 50 bucks, can't beat that. And it'd be easier on the truck, ill order them next pay period haha
I bought the same set, anyone know the estimated time it takes to do a lift key install? I know jack the front end up, undo the shock bracket, and then take the keys out. I was gonna use a big C clamp and just pry the end off of it like they did in trucks.
With the proper tools I can safely swap out keys in under an hour, but this is on my truck. Your keys may be seized to the bars, the C-clamp you use might break, who knows. I will tell you this though, keep in mind that your torsion keys/bars support the whole weight of the front of your truck so it takes a lot of force to load them, while the C-clamp will probably work to unload and remove your stock keys it may not be up to the task of loading your lift keys. The difference in the clocking of the hex hole doesn't look like much but you'll be amazed at how much force it takes to get it into position. I was lucky and was able to borrow the G.M. tool from the local dealer (I know someone!), I know it's probably going to be difficult for you to get your hands on one without buying one, but you can also try a large gear puller, 7-ton or larger, just go slow and be careful and don't put any part of your body under the key when your loading it! No need to unbolt the shocks, not sure where you got that info, but the shocks don't have any bearing on key installation. Hope this helps,Be safe!
7-ton Craftsman Gear puller is what I used to remove my lift keys, so I know it's strong enough. Just be careful with installation because it's more difficult to keep the puller straight when you're loading them, as you tighten the puller it tends to try to pull to one side. Also use some lube where the puller contacts the key, it'll probably still screech but the lube helps. It'll be a little scary but you should be OK , like I said be safe first! York isn't that far away, swing by the house and I'll help you if you want. (Greencastle P.A.)
Thanks for the offer Adam, I work at sears of Hanover tonight (5-9) so ill be shopping haha. I been spraying penetrating oil into the keys. Im gonna work on it tonight into tomorrow so heres for that. If I have any problems I might take you up on the offer, thanks
Just in case you have problems getting the old keys out or the new keys in, I recommend counting how many turns on the adjustment bolts on the stock keys so you can put it back how it was and your alignment wont be off too much.
I was gonna use a greese marker or a scribe to mark on the screws the stock location
Got the front end in the air, got the bolts removed but damn! cant get the keys loose. been spraying prolong penetrating spray into them for three days but still holy hell
1 - 20 of 22 Posts
