New Year's day Burb went into limp mode. Service engine and reduced power lights came on. Stopped and checked the usual suspects. Was still idling perfect. So I disconnected the battery for a bit, unplugged and reconnected the tps at the throttle body and wiggled the wires on the pedal sensor. Hooked it back up, started it and reduced power light was out. Sel was still on but seemed to be running fine. Next day fired it up and it was fine. No lights. Went to Advance to read the codes and got three tps codes.
P1220 - Tps 2 circuit
P1221 - Tps 1-2 correlation
P1515 - Control module throttle actuator position performance
So wtf? It's running fine still. Is this just an electronic gremlin? Is one sensor bad? Or both? Or the module? At $60 a pop, I don't want to replace the sensors if they're ok. I have no idea what or where the control module is.
