1 - 6 of 6 Posts
I am having problems with my 89 Silverado Reg cab 4x4. I have the 5.7ltr Engine with the 5spd manual pain in the arse. I have noticed that alot of 5spd manuals form this time have had the same problems. The problem is the truck no longer has 3-4gears. I have seen alot of truck showing this problem. I have searched but have not found anything that helps me. I would greatly appreciate any help, links, or advice. Thank you for any help.
Not sure I understand. You can't shift into gears 3 and 4?
How many miles on the vehicle?
Discussion Starter #6
Anything else?
I was told that if I took the stick out and checked some sorta pins and replaced or repaired them I could use 3rd and 4th again without the rebuild. From my understanding this not being able to shift into 3rd and 4th gear is a common problem. Eh if not at least I tried.
1 - 6 of 6 Posts
