1 - 3 of 3 Posts
Hi All!
I was wondering if anyone has tried or done a 4 or 5 speed conversion on a LE3 L6 (250 C.I.) Chevrolet C10 pickup. Currently it has a 3 speed on the column, but I would like to swap it for a 4 or 5 speed floor shift.
Does anyone know if the Muncie M26 will bolt directly to the L6 motor? I know that the 3 speed tranny is a 76 MM and the Muncie is as well.
Any suggestions?
Thanks,
Jonathan
my 1960 had a 3 on the tree and we swapped in a NP435 4 on the floor you will have to see if you have the access panel or get one or cut a hole in the tunnel, but it should be fine.
posting your truck information might help some as well...mike
Mike,
Thanks for the information. To give everyone more specifics on the truck, below is the information:
1981 Chevrolet C10 Fleetside Short Bed Regular Cab
LE3 L6 (250 C.I.)
76MM 3 Speed Transmission
Would the transmission that you told me about fit this truck as well?
1 - 3 of 3 Posts
