Discussion Starter #1 (Edited)
I have a 1986 gmc sierra 2500 3/4 ton, used to be a daily driver for years, just recently decided to do extensive body work to it. Decided to drive it for a little bit and noticed that it takes long to get out of first into second. not in a mechanical way tho because the transmission is new that i put in about 8 months ago. its a 3 speed automatic, i think it may be a shift control problem or maybe the transmission governor? im not sure. It will keep goin in 1st gear well into high rev. kinda annoying and a waste of gas. what controls the shift timing, so i can change this?
any help would be appreciated
Discussion Starter #4
fluid level good? how is the vaccum modulator? the rubber hose likes to dry out and not seal well and or fall off.......easy visual check.......mike
where is the vaccum modulator?
i have also noticed i have a hose coming off of my carb...have no idea where it would go to as all other hoses are in proper spots. its at the bottom of the carb.
tranny fluid is fine.
