On start up it runs fine ,but let warm up the injectors quit working when you give it gas. I’ve put anew fuel pump and filter on ,new tps map , switch out ecm oil sensor coolant gage anti nock sensor rebuilt the Tubi . But nothin has. Change still same problems
Let’s start with a little help from you. I’m assuming an 87-95 truck since you’re mentioning rebuilt TBI?
Please verify your fuel pressure. I know it’s a new pump, but new does not always equal good.
  • Like
Reactions: DustInTheWindAZ
New fuel pump pressure is 15 psi i just replaced the distributor it’s a little better but still cuts out it’s 93 with Vortech heads
2005 Chevy Avalanche
Have you tried measuring the resistance of each injector with an ohm meter? If one (or more) have a reading different than the rest, then you have a bad injector. I had this happen on my '89 Grand Prix.
