So last month I got a CEL and code P1516. Wiring harness looked ok, so I cleared the code and didn't have any more troubles till today.
Was slowing down to make a left turn so I was off the acc pedal, as soon as I turned the wheel the truck chugged and then died. I was able to coast thru the intersection and off the roadway. Tried to restart in N while still rolling, no crank.
Stopped, placed in park, still switch on, tried to restart again, no crank.
Turned key off for about 30 sec, turned key back on again and this time it cranked and started.
Was only about 6 blocks from the local dealer so I drove there and parked in the lot. Connected my code reader and had new codes, 3 entries of P2101 and 1 entry of P1682.
It is still covered under GM 2yr CPO warranty, and it's due for an oil change, so that's why I took it there.
I have/will leave the codes for the mechanics.
I've read that GM has have previous issues with these codes and the throttle assy, or the ECM.
Looking for opinions before I talk to the dealer on Monday to have them look at it, so I can have an idea that they aren't trying to blow smoke up my posterior.............
TIA
Scott.
TIA
Scott.
