1 - 2 of 2 Posts
HOW DO I CHANGE THE TURBO BOOST SENSOR I JUST WENT OUT AND BOUGHT ONE BUT DONT KNOW WHERE ITS LOCATED UNDER THE HOOD IF ANY ONE CAN EXPLAINE ID BE THANKFUL THANK YOU, AND THE CODE WAS
P0236 Which said
Turbo/Super boost sensor A CKT Range/perf
I just googled the code and hit images on google, it is on the drivers side of the motor in front of the grill, it has a green dot on the top of it, it looks pretty self explanitory to change out, looks like two vacuum lines and a sensor to replace. You might have to go get the code cleared after it is installed..Hope this helps, do a little searching before you ask questions, google is your friend..Good luck..
1 - 2 of 2 Posts
