1 - 8 of 8 Posts
Just wondering if the '03 2500HD trucks came with two catalytic converters standard? From the pictures I have taken, it appears that my truck has two cats and I thought that was usually only needed for a true dual set-up. They were on the truck before I bought it, so I'm just trying to see if the prior owner did some modification or if it rolled out of the factory this way. Also, since I don't have true duals now, are two cats overkill?
yep one on each pipe before you get to the muffler.
Alot of people cut off the "Y" pipe behind the cats and run true duals. There is no performance gain with this mod unless your putting out over 500hp. Most people do it for looks.
Discussion Starter #4
That must be what happened then because there is no y pipe at all.
Exhaust from 4cylinders with flow through a cat quicker than 8cylinder into 1 cat. Hope I explained that right.
Discussion Starter #6
Basically two cats on an 8cylinder truck has better air flow than one cat on an 8cylinder truck?
"Exhaust from 4cylinders with flow through a cat quicker than 8cylinder into 1 cat. Hope I explained that right."
Wow that make alot of sense, I always wondered why mine came with two cats, as well as my father's Tahoe.
the 2500 hds run 2 pipes back to the muffler so no 2 cats is not over kill and they a re high flow cats, so they stock exhaust system allthough quiet is pretty good performance wise
1 - 8 of 8 Posts
