1 - 6 of 6 Posts
I just got a 11 silverado 1500 and am looking to put an exhaust on it. I went to the local muffler shop and they said they could give me dual single in/out flow 40's. I'm assuming that they are going to put both mufflers on my original cat converter. Is this normal and if the shop does plan on putting both muffler's on one cat should I go ahead with it? Or should I go with one flow single in/dual out?
I had my Flowmaster Super 40 series dual in/dual out so it's true dual and i love it i would just run to straight pipes and add a dual flowmaster instead of 2 of them man. I also installed a x pipe that helps some with power and evening out the flow of the exhaust..
Welcome to the club. Your truck has DUAL CATS that flow into one muffler with one exit. Most likely there going to cut the "Y" pipe off behind the cats and run a muffler with dual inlets/outlets or put dual single in/out mufflers on. With the dual mufflers they stand them on there sides so there enough room. Hope I explained that so you understand.
Yes they do have 2 cat's and will be ran exactly how SILVERADOTRAILBLAZER said and can have them dual in single out or true dual's either with just one muffler..
Discussion Starter #5
Thanks for the responses guys. I could be wrong, but I looked underneath the truck and I thought that it only came with one cat stock. It looked as though there was a y-pipe coming off each side of the headers and into one cat then the single muffler/exhaust system. What doe you guys think would have a nicer rumble dual in/out flow like what Rockstarrchevy81 is running or two single in/out flows?
Wouldn't true duals be two completely separate, non-connected exhaust systems? One for each side of the engine?
1 - 6 of 6 Posts
