1 - 20 of 20 Posts
· Premium Member
I have a 2001 Silverado 1500 2WD with all-4 disc brakes. A couple of years ago I replaced the brake pads but all 4 rotors are still OE. In a couple of weeks I'll be replacing my hubs and bearings and while I'm down there with the whole wheel/rotor/hub/bearing assembly broken down, I'd like to go ahead and replace all my rotors and pads.
I'm thinking about upgrading to some heavy duty or performance rotors but am curious if those are really worth it. My truck does not have a towing package so I don't really need the heavy duty rotors and my truck is by no means a race car so I don't really need the performance rotors either. I'm just thinking that if I'm going to replace them, why not upgrade them from OE incase I ever do put a towing package on there. The heavy duty ones make the most sense (if I ever install a towing package) but I also really like to look the of drilled/slotted rotors - and I do have aftermarket wheels.
Is the extra cost worth it or should I just stick with OE-replacements? Is there a noticeable stopping power increase with performance rotors during daily driving?
I have the drilled and slotted rotors on mine with the ceramic pads that came with them and I say yes, it is definitely worth it. My brakes have surprised me many times when deer have ran out on me or a dog or just some moron stops short in front of me, my brakes just stop me. I really like how in the rain or wet road you don't even notice that your brakes are wet. I got the Power stop from Summit racing and I have had them over two years. http://www.summitracing.com/parts/PWR-AR-8640XL The pads are not showing hardly any wear. I think this is a great mod for a 2x4 Silverado. :glasses:
Upgrading brakes is always worth it. There's no point in being able to motivate these trucks down the road if they can't stop. Being able to stop better is always a plus
Drilled and/or slotted rotors means cooler braking= much less brake fade. Especially on the occasion that your towing a load. Did this with my 3/4 ton dodge and was able to stop a track hoe on a dime with a $.12 refund! 8)
having the 2000 silverado 4wd and using to tow a 4200lb boat I just replaced all my OEM original rotors and brake pads 3 years ago with the advance auto lifetime warranty rotors and brake pads. so far I have had no issues . since I live in the rust belt the rotors were with rust issues after 10years. the advance auto lifetime rotors still look good BUT if they don't I just go down and get new ones for free under the warranty.
just make sure you use the proper brake pads. when you change the braking rate the ABS can be a problem . 2wd truck is lighter than the 4wd so slotted rotors and ceramic pads could be too much.
when doing this job open the bleed screw then push back the caliper. if you do not do this you can screw up the ABS valves. work one at a time start at the right rear left rear right front then lastly left[driverside ]front..
Isn't the abs activated by fluid pressure?
[MENTION=39185]j cat[/MENTION], usually, I agree with everything you write, but I need to question your last response.
It is my understanding, that the ABS is composed of a hydraulic control unit (HCU) and a brake control unit (EBCU), they may be in the same case. The EBCU uses the ABS speed sensors to monitor wheel speed differences. When it detects a difference in wheel/hub/driveshaft speed, it commands the HCU to operate a valve to apply a wheel brake.
In the newer vehicles, the EBCU probably "talks" to the PCM so that the PCM can adjust the engine power to provide additional assistance with braking.
They are not a problem as I stated above but a great improvement in safety, Mine is also a 2x4. Again, I have been running mine over two years now and no problems at all. I would never go back to stock. :glasses:
Man, I hate to be the only dissenter, but will give my .02 worth. First, you will always notice an improvement in braking when you replace worn out pads or rotors, which I think is what many people responding are feeling. The supposed "upgrade" to drilled and/or slotted rotors results in very little, if any, improvement. Maximum braking surface with discs results from maximum contact with the pads and rotors. Reducing any contact surface, especially drilling, reduces the total surface that can be contacted, and may actually result in poorer braking. Slotting is preferable over drilling, because if not done correctly, drilling will lead to early distortion of the rotors. If you have your factory rotors properly surfaced, and use the highest quality pads you can get, you will be getting the maximum stopping power you can from original size rotors. The only way to significantly decrease the stopping distance of your truck is to increase the size of the rotor and pad, so there is more contact area. A good example of this would be installing a complete wilwood system, which runs anywhere from about $2500 to $5000, depending on what you choose. Yes, some of their systems are drilled and slotted, some are slotted, and some are flat surfaced. That is determined by application, and we are talking serious considerations, not just driving one's truck around town. Just fyi, I have used many d&s rotors, and currently run slotted rotors. After I install and break in new brakes, I take my truck to a lonely road (I try to use the same road each time) and set the cruise on 60, then, using a marker to measure from, do a max power brake at 60 mph, and measure the stopping distance. I have never seen any of my rotors make more than a few feet diff either way, but have seen the best pads make 10-15 feet diff, and that is worth it.
now this is what I like ! this is all very good info for those that don't understand. when I was in the transportation business we would test the braking rates also change the brake pad material and tweak brake pressures for better brake control . the reason for this is if you start to slip/slip then the ABS gets activated by the computer/PCM and you loose in you braking distance which is not good.
ever see what those BMW brake rotors look like ? pure brake control. the bigger the rotors/calipers the greater the brake effort and control.
- - - Updated - - -
@j cat, usually, I agree with everything you write, but I need to question your last response.
the ECBM electronic control brake module gets tested by the programed control module PCM at every start. on many of our vehicles the relay contacts get burned up and then you get the ABS light to come on with just starting the vehicle and never even braking or moving the shift lever from park.
the PCM receives the speed signals from the tranny and the front axles. then with the programing decides how it is going to act/control the vehicles failure indicators/brake components.
when you get a slide condition the pulsing is from the ABS pump and valve dump/apply of brake pressure as you keep your foot pushing down on the brake. when the speed frequencies all agree then the power to the ECBM from the PCM is shutdown to condition normal.
what I seen happen is these ABS valves can get stuck in the open no pressure position then you cannot stop. very scary . this can occur if you push back the back caliper pistons with the bleed screw closed . then all the dirty brake fluid fouls up the ABS valves in the control unit.
GM last I checked does not have a brake fluid replacement cycle . this is not good . most manufacturers of high priced quality performance vehicles do have a replacement period for these fluids.I have replaced my fluid 3X since 2000. this may be why my brakes still work very good even when towing.
When I replaced and upgraded the brakes on my truck. They were already brand new with ceramic pads. I got improved braking performance out of my upgrade
98% of big brake kits come with drilled and/or slotted rotors. I certainly don't disagree with your points. In fact they make good sense.
Another thing to consider is weak shocks a springs. Worn shocks will increase your stopping distance by an average of 10-15 feet on their own. Now, being that your truck is fairly new, I'm sure your springs are in good shape or at least I hope they are
As for the above brake fluid interval comment, my brake fluid gets changed with every brake pad change. Old brake fluid becomes acidic therefor eating away at runner seals and hoses. So, changing the fluid frequently is a VERY good idea
· Premium Member
Gm does recommend brake system inspection every 12 months, part of that inspection is to check the fluid, some shops will use test strips to check the fluids water content and acidity but most just look at the fluid for color, by time it looks dirty the damage inside has already begun, thats whats making it look dirty.
I normally change fluid every 24 mos. On resale vehicles I change the fluid as part of sales prep since its a good bet many of them have never had a fluid change.
you are right on the fluid color . when it looks off color it is too late.
keeping my vehicles as long as 17 years I only once had caliper issues . that vehicle the 2000 silverado had defective rear calipers. the caliper pistons were bell shaped. as the pads worn down the piston would stick.
failure mileage 20,000 1.5 yrs old.
my 1983 original calipers and brake cylinders no brake failures . replacing brake fluid is most always not done. when you work in a repair shop this is all revealed everyday with how some owners will run down there brakes to metal on metal.
do the brake fluid replacement. I would go to a shop with the proper ABS activating machine and do the GM brake fluid replacement bleed procedure .
with that done you should notice better braking .
· Premium Member
Discussion Starter · #17 ·
I'll be replacing the fluid as well so pretty muchan entirely new brake system (fluids, rotors and pads) so I should notice a big difference. Not that I'm having any problems right now, I just want to upgrade.
after you do all this brake work you will feel the difference. with brakes slowly loosing the brake effort it does so over a long time and you get used to how hard you push down on the brake pedal.
Buck is very dead on IMO, what looks cool or is used on a track for a very focused purpose or application is not always the best choice for a truck that tows or is just going stop light to stop light. Track cars/trucks do torture the parts on them but longevity is not always the prime concern. X number of laps are put on them and worn parts are replaced after the race is over, It's why they have sponsors. Fleet parts are usually beefier for a reason.
· Premium Member
Discussion Starter · #20 ·
I ordered my parts. I basically went with premium OE replacements instead of performance rotors.
@Kapelusprime Those are my thoughts exactly. My truck is no where near a race truck and it doesn't do any towing so I don't really need any super awesome brake system. OEs are plenty so I decided to save the money.
Thanks to everyone for all the input!
1 - 20 of 20 Posts
