1 - 7 of 7 Posts
My hydraulic lifters in my 95 Suburban 454 sound like mechanical lifters that need to be adjusted. Engine was rebuilt last year. Valve train has been noisy since. The cam is a Summit SUM-1300. I have replaced the lifters since with a set of Comp Cams lifters. Same noise. They are adjusted to 1 1/4 turn past zero lash. Oil pressure warm is 25psi at idle and 45 at cruise. Any Ideas?
What are you using for oil?
I doubt if your racing that big truck, why not use the GM recommended 10W30
Ok, but racing oil is available in 10w30; or, you could use a synthetic 10w30 and add a zinc additive to it.
I suspect if you go with a thinner oil the lifter noise will go away
Discussion Starter #7
I could try that but don't quite understand the reasoning. Plenty out there running 20w-50 with no lifter noise. First engine in my many years of driving to ever make this valve train noise.
1 - 7 of 7 Posts
