Got a question:
2001 K1500 4x4 5.3L Suburban 4L60-E
286,000 miles, but runs like a top. If it needs attention, it gets it right now.
Before we left out Friday, I had all of the fluids changed out, synthetic in every thing. ( not the Anti-freeze )
The truck used to belong to a Amsoil dealer…. So I continued using Synthetics, just not Amsoil, grossly over-priced...
8,000 lb Toy Hauler, went across the CAT scales yesterday, and the truck/trailer weighs 16,140 lbs. Includes my 420 lb Piaggio 250cc scooter.
Obviously, the truck is under powered for what I am doing, but my retirement pension and savings can only go so far, before the rubber band breaks.
What I want to do, is learn where to tap into the control lines to the transmission so that anytime, it is NOT in 3rd gear, that a Relay will be operated that will open the 12V lead to the A/C compressor clutch. Then when the tranny shifts back to 3rd the A/C resumes again.
The truck performs sufficiently well for me, IF, I turn the AC OFF when climbing hills.
I’m 80 y/o and in no hurry, when I get there is soon enough….
But, the engine is much happier without the A/C when climbing hills …
I will put a switch on the relay line to defeat this when no trailer is involved, e.g., need the tranny to work like the factory made it.
( I sure do miss my ‘98 Dodge diesel dually – sniff, dumb dumb to let it go
just as a side note, drove from Tulsa, OK to Ogallala, NE and the engine temp stayed at 195*F in 99*F temps all the way...
( I have added a good Transmission Cooler with a big ass fan sucking air thru it )
I have all of the Schematics for the truck.
