1 - 8 of 8 Posts
Have you brought this to the attention of your local dealer? There are many benefits to taking a vehicle to your local dealership. You can guarantee that technicians are certified and that the parts come with a GM parts warranty. For these reasons, I would recommend taking the vehicle to your local dealership to be diagnosed. They should be able to assist you further and have a plan for addressing the issue. I can also look into this issue further. In order to do more research, I will need some more specific information from you such as your name, address, phone number, the VIN for the vehicle, and current mileage. If you have further questions, please feel free to contact me either on the thread or via private message. Thank you.
Tricia, GM Customer Service.
When it rains hard, I get a small water leak on the front passenger floorboard. Any thoughts as to cause?
It could be a number of things, cowl drains, windshield seal, passenger door w strip, P door window seal.
Water leaks can sometimes be difficult to diagnose, so Tricia may have the right idea on going to the dealer for this one.
I had a similar problem with my current truck. took a while of having my dad run a house over the front of the truck and looking and finally found it. the culprit was the seal where the electronics run from the door to the cab (i will see if I can get a pic tonight). for some reason the waters path took it from the outside and ran right over that gromet and it was then filling up the space in the body. once that would fill it would flood the floor boards. easy fix. on the cab side I pulled the grommet/seal and put a whole lot of clear caulking in the groove of the grommet worked it back in and then made sure to caulk all the way around the outside edge of the grommet. No more wet floor boards and its been a few years. there could be other places but thats where I found mine. had to open the door when the water was flowing to see where it was getting in cuz I found the body panel that was filling first then had to find where it was getting in.
· Moderator
look at the fire wall on the passenger side. You should see a tube running down it. Put a stiff wire in the tube and clean it out. That is the drain for ac condensation. That model year is know for having a leak from the screws that hold down the cowl. You can try pulling them out and putting some silicon on the threads and reinstalling. Water leaks can be hard to find. Like a previous poster said, sometimes it takes pulling the dash apart and laying under there with a flashlight while someone soaks it down with a hose. I had an access panel under the cowl leaking on my yukon xl. the seal just vanished :gasp:
1 - 8 of 8 Posts
