1 - 4 of 4 Posts
I have an 05 Chevy 1500HD and looking for better mpg. Would like to know what kind of cold air intake and programer would be best to acomplish that for my truck and if there is any other mods i should get. Thanks
The best fuel economy possible is the direct result of proper maintenance and good driving habits. Listed below are GM's recommendations to achieve the best mileage possible. The first group includes things to consider for your vehicle, while the second are tips relating to your driving habits.
1. Always keep your tires inflated to the proper pressure as shown on the vehicle placard. This not only serves to increase gas mileage but cuts down on tire wear, further decreasing your costs per mile.
2. A vehicle that has a dirty air filter can’t efficiently draw air into the engine. This restriction forces the engine to expend energy to "breathe" wasting fuel in the process. Change recommendations are found in your vehicle Owner’s Manual.
3. Always use the proper viscosity oil in your engine. Oil that has a higher than required viscosity will create more drag on the internal components of the engine causing more work for it, especially when cold. Each Owner’s Manual contains information on the proper type of oil for your vehicle. Look for the "starburst" symbol on the front of the bottle, and the SM rating on the API circle on the back label. If you are in doubt, stop by your dealer for an oil change, and any other services required. Most current GM vehicles are equipped with oil life monitors to further assist on the "when" to change your oil.
Note: GM Vehicles DO NOT require additional engine oil additives. Some additives may cause harmful effects to the internal seals and additionally void the terms of your vehicles New Car Warranty.
4. Top Tier Detergent fuels are preferable when and where available. They help to keep your fuel injectors and intake valves free of deposits. When Top Tier fuels are not available, consider a bottle of GM Fuel System Treatment PLUS, P/N# 88861011 (in Canada, #88861012), at oil change time which will remove intake system and injector deposits. GM does not recommend any other fuel system cleaner.
Note: DO NOT confuse Top Tier Fuels with Higher Octane (Plus/Premium Grade Fuel) commonly sold at most all gas stations.
5. Using higher octane fuels in a vehicle that only required regular unleaded fuel will neither increase performance nor improve gas mileage. In all cases refer to your owner’s manual and ONLY use the octane rated fuel recommended for your vehicle.
Note: In high performance GM vehicles that DO require Premium (91 octane or higher) fuel, you MUST use fuels of at least this octane.
6. Is the Check Engine/SES light on? When the computer lights the Check Engine/SES light it has lost some ability to run efficiently. This may result in increased fuel consumption, increased emissions, and/or drivability concerns.
7. Even though current GM vehicles have 100,000 mi (160,000 km) service intervals for spark plugs if your vehicle is at that point in its life, have the spark plugs changed to assure proper running and continued efficient, trouble free operation.
8. Avoid quick/full throttle acceleration from a standstill in town and high cruising speeds on the interstates. While the optimum MPG for highway cruising speed varies from vehicle to vehicle, faster is almost always worse. If your vehicle is equipped with a Driver Information Center that displays Instant Fuel Economy, select that readout and vary your cruising speed while on the highway. The display will change continuously with uphill and downhill sections but you should quickly be able to identify on level ground the speed range that your vehicle does the best in.
9. Avoid leaving unnecessary items in your trunk. It takes power to move increased weight and that means more gasoline consumption and reduced performance. While the change may be slight, multiplied by thousands of miles, it all adds up.
10. Idling wastes fuel.
11. Your vehicle uses much more fuel when the engine is cold. This is especially true in the winter months when the engine will take the longest to warm up. Combine errands or trips so that the vehicle only needs to warm up once to encompass many different stops.
If you have further questions or concerns, please feel free to contact me directly. Thank you.
Tricia, GM Customer Service.
Besides normal maintanance, I would use synthetics in the engine, trans, and axles. A good cat-back exhaust, a K&N type replacement filter and a programmer. I picked up 1-2 mpg's after fine tuning my truck with a Diablo Preditor programmer. It lets YOU adjust the LongTermFuelTrims (LTFT's). This helps with mpg's, power and throttle response.
1 - 4 of 4 Posts
