Here is GM's take on Injector cleaning
Document ID# 1747645
1996 Chevrolet Tahoe - 4WD
Subject: Info - Maintenance Cleaning of Fuel Injectors #04-06-04-051B - (01/04/2006)
Models: 2006 and Prior All General Motors Passenger Cars and Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
This bulletin is being revised to add models and model years and update the name and part number of GM Fuel System Treatment. Please discard Corporate Bulletin Number 04-06-04-051A (Section 06 -- Engine/Propulsion System).
General Motors is aware that some companies are marketing tools, equipment and programs to support fuel injector cleaning as a preventative maintenance procedure. General Motors does not endorse, support or acknowledge the need for fuel injector cleaning as a preventative maintenance procedure. Fuel injector cleaning is approved only when performed as directed by a published GM driveability or DTC diagnostic service procedure.
Due to variation in fuel quality in different areas of the country, the only preventative maintenance currently endorsed by GM regarding its gasoline engine fuel systems is the addition of GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use P/N 88861013) (in Canada, P/N 88861012), added to a tank of fuel at each oil change. Refer to Corporate Bulletin Number 03-06-04-030A for proper cleaning instructions.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
