1 - 3 of 3 Posts
Discussion Starter #1 (Edited)
im having trouble installing the wheel studs.
i saw alot of videos and all most of them did not have the same trouble
i ordered online the set 610_434
the old ones are marked M 6177 on the studs.
Am I installing the wrong ones?
GM M6177 is the Metallurgical and Mechanical Properties of Wheel Bolts.
The Dorman 610-434 is listed as the bolts for a 2005 Suburban 1500 rear. There are 2 different stud types for that truck 610-434 and 610-434.1. The last one (610-434.1) is a bit longer and is black in color. Are you doing front or rear and is it a 2wd or 4wd?
Discussion Starter #3
I'm doing the driver side rear wheel. And it's 2WD
1 - 3 of 3 Posts
