1 - 10 of 10 Posts
Hey all!
And a very happy new 2008! :party:
I now had my '03 Burb for a month and a half and made som 2500 miles. Total on the meter is 30 K.
I've noticed an annoying (and worrying) sound, which seems to come from the left front wheel. It's a kind of rapidly pulsating rumbling noise. It goes away when I turn the wheel right ever so slightly, but it's there when going straight or turning left. I now have brand new, steel studded tires which gives more of a road noise, but this is somthing else. I'm taking it up with my dealer soon ( :grrrrrr: :rules: ), but would like to have some ideas as to the cause before that.
Any hints would be appreciated.
· Super Moderator
A noise that goes away while turning often points to bad wheel bearings. Another possibility would be brakes. Maybe CV joints, if it's 4wd.
I would've guessed CV's too. I hate em.
· Super Moderator
Under normal use, yes 30K is probably a bit early for wheel bearings or CV joints. Probably about right for brake pads. Of course, there are things that could cause the other to go bad early, such as a torn boot on the CV joint.
It will interesting to see what the dealer's shop says it is.
Discussion Starter · #6 · (Edited)
Yeah, that happened to my Grand Cherokee. Had to change the whole left front axle and repack the right CV joint and put on a new boot. Which was a pain in the a##. This boot looks good, though. :confused:
Talked to the dealer last week. He said: "Front wheel bearing! Bring it in." So I asked: "Is there a warranty covering this?" (Why am I such a jerk not getting all this in place before I sign the contract? That's what I allways do when I'm at work!? :mad:). So he said "dunno, talk to the boss :sign0023:". So we'll se what goes. Keep your thumbs! Meter is 30K.
Left front wheel bearing gone apesh*t! Cost of new bearing + work = $900. After som discussions - all covered by warranty. The car is spinning like a kitten again.
Thank's for all your tips and a big THANK YOU to the dealer. Got it fixed in 2 hrs.
:star: :sign0173: :star:
Hey all!
sounds like you have a hub problem to me
1 - 10 of 10 Posts
