Sounds like you have auto a/c. If you know your blower motor worked after you interupted the circut. The most likley cause is the blower resistor that is screwed in right next to the blower motor asm. Take the cover off and look at your blower motor. (rt. floorboard, under dash) . the control module (resistor) is pluged into the motor and is cooled by the a/c case. 2 screws and a dealeship part should fix your problem. Please! If you have a test light , First!, Disconnect the 2 wire connector at the motor and connect your light to each contact in the plug.Probably gonna have to get a paper clip for one side,& connect the ground clip to it. put the probe end into the other( Probe from rear of plug so you dont dammage the terminals). by connecting both with your test light,, you are testing for power and ground at the same time....Its a shortcut. If the light comes on when you request fan operation, Its the blower! If It doesnt, and there is power going to the other plug in the resistor,Its the resistor. Note: this is diagnosis is while the fan motor is in the failed state. Another thing I just remembered, Ive seen a couple of these repeate fail...over time..It was caused by high circut draw of the working blower motor. Replacing both is what I advised. The auto a/c blower resistor aint cheap! Good luck
