All,
I am in the process of restoring a 1976 Chevy K10. The goal of this project is to merge newer technology with the square body look that I love. I am going to use this thread to update you all on the progress and to ask questions about whether certain things will or will not work.
Quick back story. When I was 19 (2006) I bought a 1978 GMC c15 Heavy Half off of a guy for $500. I drove that truck for nearly 5 years. That was my favorite vehicle out of all of the vehicles that I have owned. I sold the truck in 2011 to a guy since I had bought an SUV (Ford Explorer) and he needed a vehicle to get to and from work. Less than 3 hours after I signed the title over to him, he got stuck on a mud road while it was raining. He tried to get it unstuck by revving up the engine and spinning mud everywhere. He over-revved the engine and spun a bearing. After that happened I regretted selling the truck to him. He sent it to scrap just a few days later. Here is a pic of that truck shortly after I got it.
[photo="medium"]95778[/photo]
The original plan: Square Body LS Swap
I found a wrecked 1982 K10. It was red, had a diesel, brand new tires, and the guy only wanted $250 for it. I didn't pass up the deal. I gave him the full asking price and hauled it home. After looking into what it would take to fix the frame and the other stuff that it needed I decided to look for another "donor" truck to take the frame from.
That is when I found the 1976. It was almost a spitting image of the 78 C15 so I knew I had to have it. The owner at the time had the same idea I had. LS swap into the square body. He sold me this truck for $800. It is a 2wd body on a 4x4 frame so I do have some modifying to do.
[photo="medium"]95780[/photo]
The frame and cab of the 1976 had also been fairly stripped of parts so I stripped the 1982 of anything else I could including the axles, transfer case, gas tanks, interior and much more. After stripping all of the parts off of it that I wanted someone offered me $200 for the diesel engine. I agreed and sold the remainder of the truck to him. Before all of this went down however we had a mishap.
I went engine shopping at a self serve salvage yard. I found about 5 engines that looked like they would be good for the swap. They were all out of wrecked vehicles so that meant there was a lower chance of the engine being toast.
While I was checking out I got a frantic call from my Mom. My brother had been in a wreck with my Suburban that he was buying at the time. My brother was sore, had a small cut above his eye from his glasses when the airbag deployed, but was otherwise fine. He took a trip down into a ravine, hit two trees, and the SUV was sitting nearly on its side.
[photo="medium"]95784[/photo]
[photo="medium"]95782[/photo]
The New Plan: Square Body L31 Vortec 350 Swap
Since the funds for the LS engine were coming from the sale of the Suburban I was faced with only 1 option. Pull the engine, transmission, and anything else I could use from the Suburban. So that is what my other brother and I did. We pulled pretty much everything out that was under the hood. I took as much of the wiring loom as I could from the Suburban. I also took the gas tank, front seats, wheels and tires, break booster and master cylinder, and the list goes on. I figure if I don't use it I can always sell it.
Where I've been, Where I am, Where I am going
Completed tasks:
- Computer programmed
- Wiring harness on engine is stripped down to bare minimum
- Motor mounts are purchased
- Good wheels and tires are on the 76
Current in process tasks:
- merging harnesses
- engine lower intake gasket, water pump, oil pan gasket replace
- emissions delete
- working on interior - looking for gauge cluster that better matches what I want.
- rad cooling fans - going this route because I have always been a fan of cooling fans - Not going to debate about which is better.
Future tasks: (That I know of)
- Mount Suburban gas tank under the 1976
- finish refresh on engine (tuneup)
- install engine/wiring/etc.
- install rad/transmission cooler/etc.
- install adapter and place manual transfer case from the 82 on the 4L60E
- have driveshafts cut to length
- brakes and e-brake
- A/C install
- 1998 cruise install
- interior refresh
- body work
This isn't an all inclusive list but it is a good start. This is a slow process since I have lots of other things going on but it is good. It is better to take my time and get it right the first time. As said before I will document what I have completed on here and share my ideas as well. I am welcome to suggestions but as a disclaimer don't get mad if I don't take your suggestion.
I hope you enjoy seeing the progress and the final truck once it is built!
Completed tasks:
- merging harnesses
- emissions delete
- A/C install
- interior refresh
- body work
