1997 4.3L Blazer, "ticking" noise
4.2K views 3 replies 2 participants last post by  UtahUtes
#1 ·
I just bought a 1997 Chevrolet S10 Blazer with the 4.3L V6 for my fiancé for a winter driver for her. The price was right at $1000 with new tires, CV joints, and brake lines. It has just a bit of rust on the drivers rocker panel but overall it is very straight and has good paint. I got it for that price as the guy had it listed as having a tick in the motor and his mechanic said it was a lifter or rocker arm. Of course I had to buy it as I cannot pass up a bargain and we needed a winter driver anyway. I went through it this past weekend and checked all the fluids, brakes, etc, and all were relatively new. I have tried to isolate the ticking noise and have come up empty thus far. There is no CEL and no history in the ECU of past codes. Truck only has 130K miles on it and the guy had owned it since 1999 (older gentlemen, typical Iowa nice). The sound does not make it's presence known until the engine warms up. It will make this "ticking" noise at idle and on acceleration up until about 30 mph then it goes away on acceleration. At a steady state cruise it does not make the noise nor does it when I am going up hills, as you top the hill and start back down it will start to "tick" again until you give it gas. It kinda sounds like a valve tick but then not really and it does not behave like any SB tick I have heard before.
I have tried the following:
1. Stethoscope on the oil pan - typical rotational noise, normal
2. Stethoscope on the oil pump - typical rotational noise, normal
3. Stethoscope on the rocker covers - no ticking
4. I pulled the serpentine belt off and ran it and the noise was still there at idle
5. From under the truck it seems to be coming from the right side of the engine
6. From the top the noise seems to be coming from the intake area
7. Exhaust donuts seem to be ok and not blown out
8. I drained a quart of oil out of it and replaced it with Lucas Oil Stabilizer, ran it about 100 miles to see if the pitch or frequency would change and there was no discernable difference in the noise.
I am leaning towards an exhaust leak of some kind. At this point I am just having her drive it as she is working from home and drives very little. If it gets worse I will get more aggressive in my troubleshooting but at this point I am going to just keep an eye on it. Does anyone have any ideas as to what could be the source? The truck cleaned up really well and I could easily sell it for over twice what I have in it down in SW Iowa.
#2 ·
Totally going out on a limb here:
So it warms up, thermally expands, and starts ticking........... I'm guessing a small leak in the exhaust where it bolts to the motor. Have you verified all of the manifold bolts are present/not broken?
What doesn't make sense is the lack of noise while climbing hills...Unless the rearward lean of the motor on sloppy engine mounts is plugging the hole. Wouldn't be the weirdest thing to happen.
When accelerating at speed (when you say it doesn't happen above) are you really getting on it or applying similar acceleration as when you pull off the line? Again, sloppy engine mount lean could be plugging the hole. You may also just not be able to hear it over road and wind noise...or that stereo. I'm guilty of the volume knob repair method more than I want to admit. 😁
#3 ·
Hello Jacob,
Thanks for the reply. To update a couple of points. I have been running with the stereo off to try and eliminate the "work truck fix" to noises (i.e. any noise can be cured by turning the radio up).
I have not checked the header bolts and that is a very good point. They are rather tough to get at (weak excuse I know). But I need to take a look at them this weekend. When I am accelerating I am not really getting on it at all, just normal acceleration; I have not got into it hard to see if it goes away. Again a good point and I will give that a shot as well.
I very much appreciate your reply and you made some very good points and are giving me a few more things to check out (including marginal motor mounts). Another set of eyes or point of view often helps get to the source of these issues so thank you again!
Erik
#4 ·
I have pretty much concluded it is an exhaust leak at the block. I found some carbon trails there so I am just going to run it for now and repair it in the spring. It runs strong, starts right up and shifts fine. I will do a trans filter change on it but that is about it until the spring. At that time I will address the rocker panels. I would like to have her run it for a couple years then we can sell it off for something a bit newer for her. Like I mentioned I only gave $1000 for it and for an Iowa truck it is pretty solid body-wise. Below is pic at work of the new addition to the fleet.
168209
