I have a 1997 K1500 with 5.7L engine. Went home at noon it ran fine. Got home then went to leave and it won't start....just cranks the engine with no hint of any firing.....anyone ever had this happen before?
My 97 did this twice. Each time it was proceeded by a fairly long period of taking longer to start. It typically starts right up if you bump the starter. Any way in both cases it was the fuel pump. Checking the spark, listening for the fuel pump and some other simple checks can save time and treasure. Again in my case, I could not here the fuel pump whine when I cycled the ignition switch. I do not have the stuff to check fuel pressure so I went on that and changed the fuel pump and fixed the problem. The correct way is to check the fuel pressure. If that shows you have a problem, change the filter first if you hear the pump running. If you don't hear it running get a fuel pump and fuel filter when you go to the parts store.
It's a GM thing....I tried this morning and before I turned the key to START I knew it was in vain. At the ON position I realized that I was not hearing the fuel pump. Going to call soon to have it towed and repaired. Just seems so odd that I drove home, shut it off and then nothing.
