99 suburban k1500 service 4x4 light.
1 reading
13K views 14 replies 4 participants last post by  geo1
#1 ·
My lights were out on my dash switch for my 4x4. I finally got annoyed with it enough and replaced the switch 6 months ago. After about a week the service 4x4 light came on my dash and I could not switch out of 2wd. This problem was intermittent and eventually went away.
about 3 weeks ago the light came back on. It was intermittent for awhile but now it is just stuck with the service 4x4 light on. During this time my battery died on my truck and that solved the issue for a day or 2 but now the service 4x4 light is on.
When I turn the truck on I hear a lot of clicking on the left side of the dash.
#4 ·
Most folks get one that works from a friends truck, or get a new one (and then return it), rather tha meter it. You can also You can also check the fuses if you haven't already
#5 ·
I guess I could go get a new one. I have nobody that I could borrow a switch from. The switch was brand new when I bought it. I have checked all the fuses and they were fine.
When I turn the key the switch lights up (yellow lights also). If i turn my lights on the switch is light up there is no yellow indicator light and it will not switch out of 2wd.
I am going to see if I kept my old switch. I know it worked except for the lights.
Where is the TCCM located?
#6 ·
On some the TCCM is on the passenger side panel below the dash in the panel next to the door, but on the 99 I believe it is the drivers side kick panel. You could try the fuse on The TCCM as well.
#7 ·
Is the fuse physically on the tccm module? I know there are 2 fuses on the fuse block on the left side of the dash. I found the module and the clicking on start up is definitely coming from that module. Looks like it would be a major pain to replace lol
#12 ·
If that thing has a electronically controlled actuator in the front axle it may be sticking. Get under the truck and look for one then have someone put it in 4 high and see if it's that actuator binding that's causing the clicking noises.
#14 ·
I have checked them both and they are fine.
I had thought of that possibility. However if I disconnect the battery and let it sit for 30 minutes the 4wd system works
