1998 Sonoma, the driver door hinge looks fine. The door doesn't sag. The hing pin isn't loose or wobbled out. But the little round roller that the spring part rolls on seems like is worn out. I think the inside of the roller is egged out and it makes a loud POP sound when the spring part transitions from one "step" to the next as it rolls over this roller. I've searched all over and don't see any repair kits for this. All I see are hing pin kits to replace worn out hing pins. My pin looks fin. I'm not even sure how I would get this roller out. The pin is welded in, not pressed in. Surely someone else has had this problem and found a cure. Please advise. Thanks
