Found on the internet Technical Service Information #21-NA-199 that talks about this new valve that will open at 158 degrees, instead of 194 degrees for the stock valve. This applies to vehicles from 2014-2020. I have a 2014 GMC Sierra 1500, Crew Cab, 4WD, 5.3L. When I am pulling an RV trailer, my transmission temperature is usually 194 degrees. I would like to install the new lower temp valve, but I am not sure if the new valve will work with my existing setup. My existing valve has the cooler lines that are attached with the clips, I think the new valve (86774933) is designed where the cooler lines are attached with a single plate. So I am wondering if I buy the new valve, could I then disassemble my old valve and install the new valve's inner parts to that old valve? I have called a dealership, and they said that my vehicle is not covered by this TSI.
