I am trying to diagnose fuel system problem. Fuel pressure test when cold, turn key on and spikes to almost 60psi, then quickly drops to about 10psi, but truck still starts ok. Holds pressure around 52psi. Turn key off and pressure drops rapidly. When motor hot, turn key on and climbs slowly mid 50s, then falls back down. Long crank and need to pump pedal to catch. Once going, pressure fluctuates crazily between 48-53psi. Turn off, then drops off rapidly.
From what I have read, it is probably bad injectors, fpr, or bad pump. Don't mind tackling replacing injectors and fpr, but will be super bummed if it turns out to be pump.... and vice versa. Am also worried that it could be all three, given the amount of miles and all three parts being prone to failure!
Anyone know what else I can do to better diagnose this before I start throwing money at parts?
FYI, my burb is a '96 K2500 with 7.4L, 204K miles.
Thanks!
Thanks!
