P0700 with U0073, 3 days later P0121. Any ideas?
1 reading
11K views 4 replies 2 participants last post by  Mychel
#1 ·
Hi guys and gals,
2009 Avalanche LTZ (Eco)
I searched for this combination and found a couple of threads that were similar, but not quite enough. I am sure I missed one that is the same, it seems to happen every time. Here is the history:
2017 February - Gm certified rebuilt transmission installed
2019 March - P0121 replaced throttle positioning sensor.
2019 September - Transmission rebuild and transmission control module replaced
2019 October - P0700 and U0073 Hard downshifts, flare at 3k rpm up shifting, Stabilitrack service warning.
-Dealer throws up there hands and shrugs their shoulders. Resets codes
-Truck drives basically normal
2019 November - P0121 is added to the mix
-Dealer blames the throttle positioning sensor, that was replaced a few months ago.
-Resets codes again. Trucks drives basically normal again.
I am not interested in throwing more parts at it with the dealer at this point. What is going on here? I know I am not the first person to see this issue. What set off the P0700 (generic Transmission code to trip MIL) and U0073 (Control Module Communication Bus 'A' Off)? Where should I start looking at to find the problem? I don't care if the dealer fixes it (because they warranty the work), but I want a good idea of what is going on because when I am correct, my dealer doesn't charge me for the diagnostic if I am correct. We have used the same dealer for a couple generations now.
So, ideas on the P0700 with U0073? Why did it later trip the p0121? I just had the TPS replaced.
TIA
Myke
#2 ·
I can't edit the post, but the reason for the transmission replacement was that it was going into limp mode, then one day every gear was neutral.
The reason the rebuild took place was because it was flaring between gears, hard down shifts, and apparently this is a known issue with the 6 speed transmissions. Some part that is between the gears and is to cushion when shifting tends to shred and tear up the 2-3, 3-5, and 5-r. I don't know what it means.
