Schrader valve location
1 reading
9.6K views 4 replies 4 participants last post by  Cowboytrukr
#1 ·
I want to check my fuel pressure on my 1995 S10 2.2L. I cannot locate the Schrader valve on the fuel rail. I have read that some years did not get a test port but seems to be conflicting information. Are there Schrader valves for the fuel system on this model/engine year?
If there is not a Schrader valve for the fuel system where do most of you splice in a test port?
Thank you for the insight.
#3 ·
Sorry for the delayed response 2002GMSONOMA. I have been beyond the grid. I definetely do not have a Shrader valve. I spliced in a tee at the fuel tank (PO cut out an access panel in the bed) and checked pressure. Pressure held for almost an hour at 47 psi and only dropped a few pounds afterword. I am starting to think my timing chain may be the culprit of the horrid rough running. I have been through the fuel system (rebuilt injectors and replaced pressure regulator, new fuel pump, new filter, and holds pressure.) good spark on all cylinders, and 180 compression on all cylinders. I am not sure where to go from here.
