I just had the front leather seats in my 2003 Yukon XL recovered by a professional car upholstery shop. When I got it back, the Airbag Service message displayed and the Airbag light was on. The shop owner played dumb to being the cause of the mishap, so I checked it later with my Solus Pro and it gave me the B0092 PPS code (Passenger Detection Error.)
I did a visual under the seat and didn't see anything obvious like a disconnected plug or broken wire as per the GM TSB #02-09-41-002A regarding the shorted sensor wire. So today I pulled the front passenger seat out and did another once over. Everything looked okay again so I'm dumb founded as to the cause. I tried to clear the error code but to no avail.
Anyway, my question is how do you test the Passenger Presence System sensor. My guess is that the shop damaged it when they replaced the foam padding in the seat but I don't see anything. It looks like the tube coming from under the seat, which I assume is the PPS, has fluid in it so I'm guessing the sensor works off pressure from the passenger's weight.
Any help will be appreciated.
