454 TBI Suddenly Will Not Idle, Dies at idle - SOLVED
9.8K views 53 replies 9 participants last post by  Gunny65
If the fuel gauge isn't reading correctly, you probably have an electrical problem.
It may be a loose, or dirty ground, it may be a poor connection in the harness connector, or damaged wires in the harness.
The pump also requires good clean and tight electrical wiring and it uses the same wiring harness.
Inspect and repair the wiring, you ma[ solve both problems.
