conversion van need help with rear radio
14K views 21 replies 6 participants last post by  sparkboys
#1 ·
so i have a 1996 gmc savana explorer conversion i was wondering if any one here has worked on the rear radio. so what the deal is that my rear radio has power but no sound so i was told to try to follow the wires. i checked last night and they are run by the driver side from the back all connection are good ground is good. so here is the thing i started thinking about it and thought well if i hook up a speaker to the rear and it plays on it there must be something else going on here. so i did and boom sound upon my stroke of luck i thought to re check the fuse box explorer had put in and noticed #12 and #13 were with no fuse so i thought well maybe mide did not have that option? well i looked and there is a connection for a fuse in both so then i looked and one said constant for amp and somthing else. so this is where you guys come in i put the reccomended fuses in AND nothing. so with out having to take panels off that have never before been removed i was wondering if and previous conversion van owners could tell me where they might have put and amp i am thinking on the drivers side due to the direction of the wires? would it be high or low? speakers are up high (4) and two on lower back door any help would be great thanks guy
ps loving this forum already
#2 ·
Ok, so speakers are not fused (usually). You need to get at the speakers.
Yep, a separate amp would be fused, but if you had a separate amp, the test speaker was testing in the wrong place. Did you have speaker wires on the back of the radio; or cables that connect to an amp?
If the sound is there with a speaker connected to the back of the radio, the built in speakers are either open (read bad), or the speaker leads are open.
Pull out a speaker and place your test speaker across the built-in speakers terminals. If it works, bad speaker(s).
#3 ·
but all 6 are diconnected? i was wondering if this sounds like it may be from a bad amp installed by explorer conversions ? because the radio works if i plug it into one of the factory speakers. but i was wondering where they may have put the amp for the rear? also why would there be connection in the explorer conversion fuse box and why would they run wires to said fuse box if they were not going to use it ? from what i understand these vans the were converted by individual companies were pretty much a custom job
#5 ·
Ok so update i just got off the phone with explorer conversions i was told by a grumpy old man that the reason the rear radio did not play into the speakers was because they only play thru the head phone jacks so ok ok i can buy that but then why the heck are the other six speakers not working and if that was the case i find it hard to beleive that they are running 10 speakers from a factory radio (front) ?!?! now there is a button that switches the tv from speakers to audio jacks but only a aux cord coming from the back of the tv to a two wire connection so if they are saying the tv controls the phantom 6 speakers how so with only two wires at this point i am lost???
on a side note my grandfather owned this van from brand new and i want to say i have used the back radio to play music when i was young not 100% on that been a pretty good strech of time!
#6 ·
Ok, regardless of what the guy on the phone said, the van is a house when parked, why would the factory force you to use headphones?
I don't know if you have an amp, and I doubt if any one on here knows either, you are going to have to poke around until you find out for yourself.
And, are 10 speakers connected to the dash radio, again, I don't know, but turn on the dash radio and walk around and listen to the speakers.
#7 ·
i understand about the amp was just hoping that maybe someone on here had found one on thiers. as for the 10 speakers i know 6 are not working thats what im trying to figure out why. "Ok, regardless of what the guy on the phone said, the van is a house when parked, why would the factory force you to use headphones?" because there are two one in the front and one in the back.
but i agree i will just have to start taking stuff apart for find the problem
#8 ·
Not to kick a dead thread, but I also have an explorer conversion van. In mine, the rear radio plays through headphones only, and those other speakers are for the tv. Also, my amp is under my rear bench seat. It's in a cylindrical enclosure, and it also only works with the tv.
#13 ·
so all the wires are ran into the the amp you located under the rear bench? because mine has the power folding bench/bed and if i remember right the original t.v just had an audio jack? i could be wrong about that but if im not does it run straight from the amp to the t.v?
#14 ·
I've never had the rear apart, so I'm not positive, but I believe my audio runs straight from my tv, to the switch, to either the headphone jacks, or the sub/amp and speakers depending on the position the switch is in. Is that what you were asking about?
#15 ·
well mine is a 96 but only has 50,000 miles but i am trying to figure out if all the speaker wire are connected to the amp ( i have not located yet) and if the sound wire from the tv goes straight to the amp then to the speakers?
problem is i have no sound from my original tv in the van
#16 ·
Have you made sure the switch is hooked up all the way? On my switch, there's a molex plug with 4 or 5 wires, and then there's one on its own, and if I don't plug the one wire in, I don't get any sound. Mine is an 04 though, I don't know how much they wouldve changed in 10 years
#20 ·
Thanks for the posts on this topic, as it now makes sense on my Explorer Conversion Van - Although I have a 98 Ford E150, with a high top but it was converted by Explorer. I couldn't figure out why my Rear Radio was not playing either, so started testing. I found it would play out of the Headphone jacks, but not out of any speakers. When I take a speaker wire directly out of Radio and connect to an extra speaker to test, the radio works fine.
My setup (think is factory).
Dash Head Unit plays 6 speakers:
2 - Front (in doors)
4 - Rear (2 midway back 5x8 Ford speakers, like doors)
(2 in back corners)
If I place the Dash unit to fade to the Rear only, the 4 rear play.
The other 2 small 4" round speakers are connected to a small TV mounted on ceiling.
I do have another 5/6" round speaker, only one on the wall. My guess this is for the additional TV that is mounted in high top above and between Driver and passenger seats. Haven't got that tv working yet as previous owner had some dvd connected.
So, I think the grumpy guy is correct that back in the 90's they (Explorer) might of just had that rear radio connected to Headphone jacks.
Not sure what I will do with that radio, could run a wires out on it for external speaker setup when parked. But then the dash radio works fine and runs off the same battery anyway (only one battery on van).
