There are scan tools much cheaper than $900 for crank relearning (CASE Relearn option). Gotta look at the offered available options for each scan tool.
I'm on my 3rd updated scan tool in 10 years with all the electronic crap being added to vehicles.
But to save you $900, here is the "relearn procedure" without a scan tool more near the bottom of this post.
Crank Relearn Instructions (
With OBD Scanner/Reader)
These Crank Relearn Instructions may not apply to all vehicles. But they're close to how it's done on most cars.
To perform the relearn, proceed as follows:
Connect a
scanner to make sure there are no trouble codes stored in the computer’s memory.
If there is any power train trouble code other than P1336 (Crankshaft Position Variation not learned), the computer will disable the relearn function until the problem that caused the code has been eliminated.
Also, make sure that the engine coolant (check it when the engine is cold) and oil levels are at an acceptable level.
1. Set the parking brake and block the drive wheels. Make sure that the hood is closed.
2. Start the engine and make sure that the engine coolant temperature is at least 158 degrees F. (70 degrees C.)
3. Turn the engine off for at least 10 seconds.
4. Select the crankshaft position variation learn procedure (CASE Learn) on your scanner.
5. Make sure that the transmission is in Park. Start the engine.
6. Apply the brakes and hold the pedal firmly.
7. Follow the scanner instructions.
Remember: That you are going to increase the engine speed to approximately 3000 RPM, 4000 RPM, or 5150 RPM. That’s the variation learn fuel cutoff RPM (depending upon the engine) and that it’s important to release the throttle when the engine RPM starts to decrease as a result of the fuel cutoff going into effect. Failure to do such will result in over revving of the engine, causing possible engine damage.
8. Once the engine has returned to idle, check the status of Diagnostic trouble code
P1336. If the scanner indicates that the CASE has been learned, the relearn procedure is now complete.
If CASE has not been learned, check for the presence of other power train codes. If any exist, correct the problem, then repeat this procedure.
Without OBD Scanner/Reader)
NOTE: If the Crankshaft Variation Relearn is not accessible through your scanner (some truck applications 1998 & later), perform the relearn in the following manner:
1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary.
Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.)
with the clutch depressed.
