97 Burb, K1500. I'v been dealing with an intermittent problem where my tranny looses power, goes into limp mode, gets stuck in 3rd, I loose my Speedo, RPMs, PRNDL selector light and get 6-8 tranny codes. Most of the time clearing the codes and turning the truck off n back on would solve the problem and it wouldn't happen again for a week or longer. other times jiggling the wires on the tranny combined with the above seemed to work. being intermittent made it really tough to trouble shoot properly. I figured the pink wire for pin E which carries 12+ to the tranny had to have a break.
then it became more of a permanent problem 2 weeks ago or so. I'v troubleshot it many ways. the fuse was good, had 12V. I went under inspected the wires, checked the voltage n it read 5V. I disassembled the harness quite a bit, thought I had a break in the pink wire, snipped it checked it n nope, back to 12V so I put that wire back together, soldered n shrink wrapped of course. checked it out with volt meter again, had 12 volts. I Giggled the crap out of the harness and couldnt get it to loose connection so I rewrapped the harness, plugged everything back in and resecured very well, put the shield back on and took it for a spin. well it wasnt fixed, 1/4 mile down the road I loose it again. bring it home and check the voltage on pin E and it reads perfect, giggle the crap out of the wire and cant make it loose connection. damn it!
So now I think internal harness problem, call up the tranny shop that rebuilt it, tell him whats going on and he says bring it in, if theres something wrong with the tranny he'll fix it for free even though its a few months past warranty, he dosent care. perfect. if its something else he'll let me know n go from there.
he puts the tranny on his computer and all functions of the tranny work perfectly as they should. plugs it back in and the truck fails to start. this only happened to me maybe 3 times over the last couple months and led me to replacing the ground straps. I never thought to tell him this as I thought I had fixed that problem, I also never told him I didnt have the gauges ect working, I just thought that was a sympton of the tranny loosing power, if you pull the fuse this happens... when I dropped the truck off and told him that last bit of info he suspected the ignition switch but would go ahead with the diagnosis...
so he gives me a call a couple hours later to tell me everything he done and the diagnosis is the Ignition Switch, got him to ball park the fix, he says $300 for the part and maybe another $200 for the diagnosis n repair. I declined the fix and thanked him for all his work.
go to google and the first video I see is for 97 gmc ignition switch list the symptoms as being exactly what was happening with my truck complete with every tranny code I have.
man do I feel like a dumbass!
now iv found a few replacment parts and holy crap they are pricey! range from $175 delivered to way more than $300!
anyways im blabbering on cuz im kinda ticked off... LOL. $100 For the diagnosis and a couple hours of work, I dont even think he billed me for the labour. so I learned something new today.
Cheers!
Cheers!
