Good evening to you all,
I am brand new to this forum and was looking for some mechanical advise. I recently installed a reman 5.7 Vortec in my 96 K 1500. Runs great...however when I slowly accelerate it sounds as I am getting a valve rattle but its not. It is more of what I call a dieseling sound until she shifts back. At 1,000 rpm my obdII is reading +19 degrees on the timing. It should be +/- 0 degrees ?? Also I am getting a crankshaft sensor code. Could this be the crank shaft sensor or should I look into lifting my distributor and rotating one tooth ? I have tried turning the distributor but don't nothing happen.
Thanks in advance for any and all advise !
