96 Chevy 5.7L Distributor and Crankshaft Relearn Question
1 reading
28K views 2 replies 3 participants last post by  Motor City Rick
#1 ·
Hey Everyone,
I have a question about the distributor and Setting the timing on my truck. I have a 96 Silverado K1500 5.7L and am in the process on replacing the intake manifold gasket on the motor. It looks like it's necessary to remove the distributor in order to get the intake manifold off. I know that I need to set the distributor to TDC 0 degrees on a compression stroke for the #1 cylinder before removing the distributor from the truck. I was going to make marks on the distributor and motor relative to how it was positioned prior to removal.
My question is, once I remove and drop the distributor back in, is the crankshaft relearn procedure going to have to happen no matter what once the distributor is pulled - even with TDC at 0 degrees? And if so does this year truck use a OBDII scanner function or a timing light scan tool to set timing; I've heard conflicting reports. Thanks
#3 ·
Okay @FatMatt336 ,
Here is your written relearn procedure:
Crank Relearn Instructions (With and Without a OBD Scan tool)
These Crank Relearn Instructions may not apply to all vehicles. But they're close to how it's done on most cars.
To perform the relearn, proceed as follows:
Connect a scan tool to make sure there are no trouble codes stored in the computer’s memory.
If there is any power train trouble code other than P1336 (Crankshaft Position Variation not learned), the computer will disable the relearn function until the problem that caused the code has been eliminated.
Also, make sure that the engine coolant (check it when the engine is cold) and oil levels are at an acceptable level.
1.
Set the parking brake and block the drive wheels. Make sure that the hood is closed.
2. Start the engine and make sure that the engine coolant temperature is at least 158 degrees F. (70 degrees C.)
3. Turn the engine off for at least 10 seconds.
4. Select the crankshaft position variation learn procedure (CASE Learn) on your scan tool.
5. Make sure that the transmission is in Park. Start the engine.
6. Apply the brakes and hold the pedal firmly.
7. Follow the scanner instructions.
Remember:
That you are going to increase the engine speed to approximately 3000 RPM, 4000 RPM, or 5150 RPM. That’s the variation learn fuel cutoff RPM (depending upon the engine), and that it’s important to release the throttle when the engine RPM starts to decrease as a result of the fuel cutoff going into effect. Failure to do such will result in over revving of the engine, causing possible engine damage.
8.
Once the engine has returned to idle, check the status of Diagnostic trouble code P1336.
If the scanner indicates that the CASE has been learned, the relearn procedure is now complete. If CASE has not been learned, check for the presence of other power train codes. If any exist, correct the problem, then repeat this procedure.
NOTE:
If the Crankshaft Variation Relearn is not accessible through your scanner (some truck applications 1998 & later), perform the relearn in the following manner:
1.
Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.) with the clutch depressed.
Hope this gives a little help in your endeavors?
