This is probably an old issue and I have looked through some of the threads on it but nothing so far has helped. I unplugged the connector at module under hood to check but no power to pins A, B, C. Pin D seems to work normally after changing brake light switch but no power to the others. Checked fuse - good. That leads me to think multi function lever switch but unsure since no power to pin A.
Is there something else I'm overlooking?
Thank you,
Laurie E Williams (new to group)
Thank you,
