My question is, ...did you torque "ALL" bolts / fasteners on the intake "assembly", …or just the intake bolts???
Second, if you had "rust" in the fuel channel, or in the injector itself, the injector is trash. You "CANNOT" clean microscopic particles of rust out of any fuel injector. Also plugs up the internal screen within the fuel injector itself. There is "NO" chemical to dissolve rust particles. If there's rust further up the line and cannot be cleaned out, ...those fuel parts have to be changed also.
Third part, ...did you use a o-ring lubricant on those fuel injector seals or just pushed them in dry???
