Best spark plugs for the 5.3
3 reading
161K views 27 replies 15 participants last post by  rocksolid162756
#1 ·
Iridium or platinum ac delcos or another brand?
#3 ·
I had ac delco plats .. also OEM factory plats ... the platinum melted off the plug tip vaporized.. so I using forum recommendations installed the Iridium plugs ..at 30 to 40K miles the plats got melted so with the Iridium plugs I checked at the 40K miles and plugs looked like I just put them in .. been in there now several years... perhaps 80K miles now on them.. some reported they lasted 200K miles..
ON my toyota truck they are factory Iridium plugs and manual says 100K miles is the normal plug replacing .. some go higher like 130K and found the plugs still looking good..
ac delco I have in there so I would recommend that manufacturer .
#4 ·
x3....On Going with A/C Delco Iridium Plugs, Also Check the Plug Wires, and if They Haven't Been Changed Out in a While This Would be a Good Time to Install a Fresh Set, and If you Go with A/C Delco Iridium Plugs, Keep in Mind that the Spark Plug Gap is Set During Manufacturing and Should NOT Be Changed or Damage to the Spark Plug May Result....Gap on the A/C Iridium Plugs is Gaped to 1.01mm (0.040 inches).....
#6 ·
x-5 on the Iridium plugs.
But as for the gap on Iridium plugs, I find the vast majority 75%+ are not at the .040 gap as claimed. Stick a wire gauge and see for yourself. Allow a 0 to .003 tolerance of the .040 gap on clearances when measuring. There is no such thing as a "pre gapped" spark plug when AC kicks out over a couple hundred thousand an hour in production.
I'm one of the very few that still has the gauge fixture for 14mm plugs to get them at the designated gap. I got so tired of the "pre gap" statement from techs, then I go in and re-gap these plugs to cure a roughness issue. It same belief of slamming a crank and rods and not checking clearances. Your an idiot if you don't check rod and crank bearings as well as spark plug clearances.
#11 ·
Liam, your review appears to be opinion and perhaps personal choices.
I agree with your #1 and your #2 choices; but I have nothing but gut feelings and personal preference to go by.
To rate those plugs as you have rated them requires rigid testing and the publishing of the results.
The results will allow you to rate the plugs in a constant state of environment.
Do you have these tests and the results to backup your choices?
#13 ·
It is labor intensive, but you can't make claims that one is better than the other without documented proof.
You need to devise tests that will backup your claims, actual performance results.
chart the results and list in the order of good to best.
#14 ·
This is funny (coincidence), last night I watched a show on Motor Trend where they compared the stock AC Delco plugs on a 5.3L with the E-3 ones. On a dyno they ran 2 pulls with each and averaged HP & Torque. The E-3s gained somewhere around 5 - 7 in both. The E3-s used a little more fuel but, with the gain in HP they said you'd get better mileage too I was under the impression that they were just a gimmick but, I guess not, ha ha.
