Break lights
1 reading
1.4K views 8 replies 6 participants last post by  j cat
#1 ·
I have a 2006 chevy silverado have no break light. All fuses are good and all bulb are good the third light is not working either and replaced the break light switch. have power going in to switch but nothing going out thanks in advance
#3 ·
If the switch is good, there will be 12v coming out of it..
You say it is new, therefore it is likely good.
Therefore if 12v goes to the switch, 12v will go through the switch when the brake pedal is pushed.
This assumes the switch is properly installed and the brake pedal arm does not touch the switch when the pedal is pushed.
