Hello all, my fan resistor keeps flowing out and I can't figure out why. Any thoughts?
The most common reason for repeated fan resistor failure is an electrical overload. The fan resistor is designed to handle a specific amount of current, and if the fan motor or wiring is faulty, it can draw more current than the resistor can handle, causing it to burn out. Check the fan motor and wiring for any signs of damage, corrosion, or loose connections.bitlife said:
07 1500 Classic, 50k miles. Everything looks good, no breaks, no melted plastic, no discoloration. Idk how to check the amp draw. Otherwise everything looks good.Year, make and model? How does the connector and wiring look? Any signs of melted plastic in the connector? Any discoloration of the wires? Pull back the wire loom on the leads to the resistor and inspect wires. Check amp draw on blower motor. Is the resistor getting moisture on it?
Thank you I'll look into that.The biggest reason the resistor assembly burns up is because the wiring and the connectors are not big enough.
The connector starts to burn and overheats, then the heat causes the wires to burn off.
When you buy a new resistor, you should also replace the wire harness at the same time.
Just look at the connector the resistor assembly plugs into07 1500 Classic, 50k miles. Everything looks good, no breaks, no melted plastic, no discoloration. Idk how to check the amp draw. Otherwise everything looks good.
