21 - 39 of 39 Posts
The thread you want to read is "quick fix" for p0446. There are several causes for the 445 and 446 codes but I think this one covers about everything.
https://www.gmtruckclub.com/forum/t...-p0446-evap-emissions-vent-circuit-low.18964/
Ted
Ted
Pulled the canister and it is full of loose pellets, so it needs replacing. The small line that has the blue retaining clip is stopped up with pellets. Do I blow into the canister end or the other end, and is the other end the on the purge solenoid on the engine?
Topping off the tank is verboten. Gas in an underground tank is way colder than ambient. After you top it off it will expand and travel through the evap system. You'll see the result when you open the canister and hoses there. You can possibly clear them by opening BOTH ENDS and using shop air. Sometimes they need replacing. Don't blow charcoal into your fuel tank.
Edit: You keep saying no codes. Didn't this start with a stored P0445?
Ted
The only code I initially had was P0455 and I with Tighten the gas Cap. I cleared it after tightening the cap and have not had any codes since. Took the canister off and it is shot, carbon is pouring out of the large pipe. The small hose with the blue lock is plugged with pellets. It must be the vacuum line from the Purge solenoid on the engine. Is it safe to to disconnect the line from the Purge solenoid and blow it toward the disconnected end that was attached to the cannister?
You don't want to blow charcoal pellets where they don't belong. Make sure each hose is disconnected at both ends before you blow it out. I've never had to do this. If it's not to much trouble then remove each hose completely one at a time and reattach so you don't mix them up. A new canister is filled with charcoal pellets but they aren't soaked with fuel.
Ted
  • Like
Reactions: Retiredmastertech
Every once in a while I choose to read a post, such as this one, that has been resurrected. As I start to read, I get excited because @Motor City Rick is back, then I see the dates and am disappointed all over again!
For a while we had a user, screen name of Motor City Rick, he has some posts on the first page of this thread. The guy was amazing at knowing what the fix was. Especially if it involved wiring and needing wiring diagrams. He must have had every shop manual from the beginning of GM until now available! He just disappeared. We all miss his wisdom and guidance! He probably got tired of all of us " idiots asking childish questions" that @mommatried84 couldn't handle either!
  • Like
Reactions: xPosTech
I think he wore his two fingers out. :cool:
Ted
  • Like
Reactions: JackE
Ted
Disconnected vacuum line at Purge Solenoid and it and line full of carbon beads. After multiple shop air blow outs all beads cleaned from line. Cleaned solenoid and as soon as tank comes I can put it all back together. Thanks for your help!
Got a code in Sept. the Vap Solenoid failed. Replaced the one under the vehicle near the gas tank. Two months later I am getting tighten gas cap notice on dash. Cap was tight and good but bought a new one since it was the original one from when I bought it in 05. Still getting notice on dash. Have not checked for codes yet. Will do it tonight when I get home. The other day I forgot the gas cap off after filling up the tank, would that cause me to be getting this notice on my display?
Yes it will, also corrosion on filler neck can cause poor has cap seal
Try taking a heavy rubber mallet and wack the underside of the gas tank a few times. inside the gas tank at the bottom of the fill hose leading into the gas tank is a spring loaded rollover safety valve that may have gotten stuck not allowing fuel to flow into the gas tank, you may also pull the fuel fill hose off the gas tank inlet and take a small wooden stick to possibly push the valve open. just my thoughts. happened to me before.
3 lines came off the evap canister.
--1 line ran to the vent solenoid which i did not blow air through (its a short hose and when I shook it I didnt hear any rattle inside)
--a smaller line ran towards the front of the vehicle. once it passed the tank it had a connection I was able to undo. Therefore I was able to blow air towards the rear of the vehicle and ended up getting a lot of charcoal out this way. (yes the line was disconnected)
--a third line ran to the tank and I was unable to disconnect this line without dropping the tank. I loosened it from the canister and shook a lot of charcoal out and then decided to blow air into with the gas tank cap off (maybe a bad idea)
My next idea is to check a evap line someone on another forum said runs off the filler neck. I will also blow air through the small vent line from the canister to the solenoid valve. After that I am out of ideas.
Hello, don’t want to go through the whole post if not necessary if can even get a response. Is anyone still responding here?
Anybody?
I did browse the first thread on here but my 05 Suburban has never thrown a code. bought it with 91k and it now has about 165k
http://www.gmtruckclub.com/forum/threads/how-to-fix-code-p0449-evap-pics-video-and-part-s.110446/
Issue is as stated. Can fill about a half gallon at a time unless i really slow down the gas pump. Hear gurgling, and then pump shots off. Did my research and replaced the Vent valve ($21, AC Delco) with no success.
Whats next?
----Any specifics on checking and/or cleaning the vent lines? Can't find a video on this as most of my search results lead me to replacing the vent valve.
----charcoal canister? More expensive so havent jumped on this yet
Any and all help is appreciated, thanks
Just wanted to thank you guys for all your information on this subject. I have a 2009 I had been battling this issue along with large evap leak. I replaced the charcoal canister yesterday after replacing everything else. that was the main issue for me. not only is my truck now running better than it did when i bought it. but for the first time ever. its actually taking gas at the pump like a normal vehicle. thanks again .
Happy your situation was resolved with a new canister!
now does anyone here know much about a 2007 Chevy Colorado’s anti roll over or anti siphon valve in the base of the tanks filler neck?
im on tank 3, not taking in gas- the valves seem to get stuck. Last 2 tanks from junkyards have had this issue. Im very frustrated and cannot understand the mechanism so I can attempt to repair or replace it. (I know it’s not a repairable or replaceable part, but it can be…)
Thanks a ton in advance!
21 - 39 of 39 Posts
