So I have a 1997 Suburban k1500 5.7
Never really had a problem until recently and now everything is going crap.
My fuel supply line rubbed up against the firewall pinch weld and pull a hole in it. I drove it like that for about 2 weeks until I got a replacement line from rockauto. So the line comes in and I replace it and the fuel filter, everything is alright.
Then my bad battery killed my starter so I got a starter and a battery, anyway back to the issue.
I'm getting a sort of hard start problem going on. Sometimes I can walk outside in the morning jump in and turn the key and bam it starts right up. Then other times it cranks a little long and once it starts you hear the starter go wer(no idea how to spell that noise). Priming the pump doesn't produce any different results as far as starting any quicker. It seems to be intermittent almost. When it does crank awhile and finally start it takes a second to get up to idle like its not getting fuel or something.
Any ideas?
Any ideas?
