hesitation on acceleration, no codes
1 reading
23K views 28 replies 13 participants last post by  DrivinMike
#1 ·
2008 Silverado 5.3
I'm annoyed with the hesitation when I try to accelerate quickly. No problem most of the time, and if I accelerate slowly, it runs perfectly, smooth as silk. It's just from an idle, typically at a stop light.
No codes, no other problems.
#5 ·
Torque Management
What is torque abuse?
"Abuse Mode is part of the transmission Torque Management. It operates from 0-1600 rpm in first gear only. If you stomp the gas from a dead stop or from a very slow speed, the Abuse Mode program reduces engine horsepower to prevent any possible damage to the transmission.
#6 ·
Unfortunately, I'm not trying to accelerate that aggressively, just taking off normally from a stopsign. I have to feather-touch the pedal to go without hesitation. It's clearly a misfire, but it just happens when I first touch the gas pedal from a full stop or slow roll. If it were a carbureted engine I would think accelerator pump but with TBI I'm puzzled.
#8 · (Edited)
Might be carboned up throttle body that's sticking.
When the throttle body gets dirty, it has a direct effect on how smoothly the engine operates. Signs indicating a problem include rough idling, jumpy or sluggish acceleration, poor fuel economy, and stalling. With the use of a throttle body cleaning product, the dirt and debris buildup are easily removed.
#11 ·
Most like
2008 Silverado 5.3 I'm annoyed with the hesitation when I try to accelerate quickly. No problem most of the time, and if I accelerate slowly, it runs perfectly, smooth as silk. It's just from an idle, typically at a stop light. No codes, Most likely one of two things not enough air (air filter) or not enough fuel. Dirty gas filter or dirty injectors.
