I know that you can swap ECMs to the ECM from a LS engine. Its called the 411 or 0411 swap. It takes repining the connector for the OE ECM. There is a ton of info on LS swaps on you tube. If you want to get in touch with someone who has done the swap, You should try
https://www.gmt400.com
That forum, is just for OBS 1988 to 1998 body style trucks, Burbs, Tahoes. There is a member there that has done the swap. You will have to join to post of course, but it is also a grate forum. There are several members with LS swapped trucks also.
