I've been trying to diagnose why my 1996 GMC Suburban 7.4L is hard to start when the engine is warm. By hard to start I mean it takes a long time to start 20 - 30 seconds. The engine cranks over fine so there doesn't seem to be a problem with the battery or starter. When the engine is cold it starts quickly - just a second or two at most. But after the engine has been run for a while and I try to restart the engine it's very slow to start and I get a "rich" smell of unburned fuel from the exhaust pipe. It seems like the problem is worsening in recent months.
So that's the story - now on to what I think may be the problem. Are my fuel injectors leaking down? I've been researching this but not quite sure how to diagnose the problem.
I see a pressure port for the fuel system at the front of the engine. It looks like I can buy a simple fuel pressure gage to check the main pressure but that doesn't help me diagnose which, if any, fuel injectors are leaking down.
In the service manual I found information that indicates 56 - 62 psi for fuel pressure at the port near the front of the intake manifold. How long should it hold that pressure when I turn off the engine? If the pressure drops quickly I guess that's an indication of a leaking injector(s). How do I determine which one is leaking? Maybe it's more than one.
On a related note - the local Chevrolet dealer wants well over $1000 to replace the upper and lower intake manifold gaskets. Instead, I'll do this myself and that's the perfect time to diagnose and replace fuel injectors. With 160,000 miles should I just go ahead and replace them all? That's expensive but I don't want to do this twice.
Which injector brands are best? I like the idea of AC/Delco but am open for suggestions. I found new (not rebuilt) prices for AC/Delco are $100+ each and brands like Delphi, Bosch and Lucas are more like $50 each. Any comments?
Thanks for your assistance.
