Just received a call from the dealership.
My vin has no recalls, and I am 4k miles out of warranty.
New power steering rack needed. Over 1600 bucks. Fml.
save your receipts and dealership repair documents.. could be a year from now this will effect your truck and then you will be compensated for your loss.. even if you dumped it , for another truck..
I complained about my park brakes wearing out @15K miles .. never use park brakes automatic well after a few years so many owners filed a class action lawsuit .. I did not pay any amount since it was only 1 year old .. they just checked it out .. said yes parking brakes do wear .. I said that is B/S.. what I found was the park shoes were flopping around , not properly designed , so the hold down clip was not proper..I actually fabricated a clip and the clip I designed is still there 17 yrs old.. I did replace those park brake shoes but dealership did not ..
most likely the rack motor is dead ..racks usually fail because of leaks and slop ...I would replace the motor
or
The defect: corrosion of the connector between the electric power steering module and the torque sensor connector may cause a loss of electric power steering assist.
